cam install questions
i will be installing a 2002 ls6 cam, with the springs and retainers, what else will i need, i am trying to keep this cam unnoticiable, so what else would i need?
thanks
btw, i also have the spring tool, i just need to know what else i need
jimmy
thanks
jimmy
Re: cam install questions
A new front engine seal, new crank bolt, I don't know your mileage, but possible valve seals. Depending on what year your car is, a new water pump gasket. www.ls1howto.com has everything you'll need.
