MS4 Cam swap, do I need an underdrive pulley?
Old 07-29-2007, 02:08 PM
Flamin' bird's Avatar
Default MS4 Cam swap, do I need an underdrive pulley?
We're planning to install the MS4 and I've been reading that alot suggest putting a underdrive pulley on but I would like to know if it is absolutely necessary right now. If I dont need it right now that would be great because otherwise since it's so expensive for the pulleys and belts it would set everything back and I still have more things I do have to get for the install
TIA.
Old 07-29-2007, 02:21 PM
sroach20's Avatar
pulleys are what you get when youve got every other bolt on available.
Old 07-29-2007, 03:01 PM
ELMiN8oR's Avatar
it's not necessary, we have a bigger cam/heads in my friends vette and a stock pulley, dynoed about 698 rwhp. but if you want more rwhp ? $260 not alot of money for more power
Old 07-29-2007, 04:12 PM
Thanks for the replies. While $260 may not be alot it is when that's about all I can spend every 2 weeks or so on the car . I still have to get the pulley puller, cam install tool, and the fluids I will need along with a few other things
Old 07-29-2007, 04:22 PM
StripedZebra's Avatar
Go to auto zone and rent their pulley puller for 40 bucks. You get the money back when you return it.
Old 07-29-2007, 04:35 PM
Cool..thanks! I'll do that
Old 07-29-2007, 08:32 PM
ArcticZ28's Avatar
It'll net you some decent ponies for the price, but it's not necessary, it's just quite convenient to do it while you already have the stock crank off as it's sometimes a PITA to put it on and take it off. If you don't have the money, don't worry about it. It can be done anytime. It's mostly a convenience thing along with "why not, I'm already down there".
