What you guys think about this cam?
That cam is fine, as long as you aren't putting this in your daily driver. Need more details to confirm.
How much are the heads milled?
What is the static compression?
What gears are you running?
What is your intended use?
That cam needs 12:1 compression, but you may have some PTV issues, depending on the size of the valve reliefs your pistons have. It will also work better with at least 4.10 gears, but could go to 4.30 or 4.56 depending on the tires you are running.
