LS1 with 5.3L heads
Old 08-09-2007, 12:39 AM
Dirty 30's Avatar
Default LS1 with 5.3L heads
If using a stock LS1 block with an LS6 cam and stock 5.3L heads, will the pushrods have to be the shorter aftermarket ones or will the stock ones work?
thanks
Old 08-09-2007, 12:48 AM
transam45's Avatar
the stock ones should work
Old 08-09-2007, 07:41 AM
BIG_MIKE2005's Avatar
stock length will work fine.
I'm runnin the following on 7.4 pushrods:
Stock bottom end
224/224 .581/.581 114
P/P & milled .018" 5.3 heads
stock rockers
7.4 chromemoly pushrods
FelPro(stock replacement LS1 head gaskets)
Old 08-09-2007, 09:45 AM
Dirty 30's Avatar
ok thanks. Im just wondering if i would be better off swaping to LS6 heads.
Old 08-09-2007, 09:59 AM
of coarse you would. But I would upgrade to at least a set of P/P LS6 heads & possibly at least a 224 cam or you might end up doin it all again later if it doesn't pick up as much as your hoping for.
And if you do heads don't forget to at least upgrade to LS7 lifters.
Old 08-09-2007, 10:01 AM
Dirty 30's Avatar
k, i'll probably just go with stock heads. im not looking for big hp/speed etc. Its for my truck.
