What do yall think???
Old 08-10-2007, 12:43 PM
o2redws6's Avatar
Default What do yall think???
What do yall think about a 293/297 114 +4 comp cam can any one streetable tune it?
Old 08-10-2007, 12:50 PM
TheLS1Kid's Avatar
If 293/297 is the duration at .050 that is a HUGE cam.
I highy doubt that is correct, did you read it wrong?
Old 08-10-2007, 01:52 PM
transamfreak01's Avatar
yeah theres no way that can be right.. did u misread something maybe?
Old 08-10-2007, 02:46 PM
5.3LJimmy's Avatar
That's gotta be the advertised duration. Assuming XER lobes that should be 244/248 .612/.615 114 +4. That's almost a TRex on a 114.
Old 08-10-2007, 03:42 PM
Restricted User
socmguy's Avatar
yeah, that's crazy talk right there. You *do* know there's only 360 degrees in a circle. 293/297 that wouldn't even look like a lobe, haha!
Old 08-10-2007, 03:43 PM
o2redws6's Avatar
I will double check and make sure I am reading the card right, I am probably reading it wrong though. 5.3LJimmy was right on the lift, the car is tuned speed density and it's throwing a weak signal from the o2 and I have already changed 2 times and I have no vacum at idle so I hardly have no brakes. Its throwing a map sensor code and tps code. Before the cam I had no problem with any of those codes.
