Can you guys help me me figure out what push rod length do I need for my H/C set-up?
Im going to put some TSP Terminator heads (milled to 59cc) on my C5 with a 228/228 .579 .579 114. What push rod length should I be using? IF you guys can help I would appreciate it a lot.
Roger
Roger
Originally Posted by JPH
how much have they been milled?, and what head gasket are you going to use?
Originally Posted by LSXNV
the only good way to find that out is using a pushrod length checker. and making sure your roller tip is centered on the valve stem/lash cap correctly using marking compound.
