Bolt specs needed :)
Does anyone have the specs on these bolts for the ls1??
Flexplate to crank bolts
Stall to flexplate bolts
Bellhousing bolts
Crank sensor bolt
Cam sensor bolt
coolant crossover bolts
Thanks so much for any help you can give me.
Bellhousing bolts
Crank sensor bolt
Cam sensor bolt
http://www.ls2.com/boggs/torques/enginetorques.htm
had to ask SilverSierra~
i'll be using these this weekend for sure~
Flexplate to crank bolts--- A4 flexplate bolt (m10x1.5x23-g) (need 3) (98-00 LS1) = 12560397
Stall to flexplate bolts--- 12mm x 1.5 the length is 20mm (this was with a TCI flexplate though and not the stock one...you may need shorter ones)
Bellhousing bolts--- M10x1.5 - couldn't find the length
Crank sensor bolt
Cam sensor bolt
You also need motor mount bolts
Crank sensor bolt
Cam sensor bolt
