Will Yella Terras reduce my P/V by more than .005?
Old 05-29-2003, 12:09 PM
verbs's Avatar
Default Will Yella Terras reduce my P/V by more than .005?
I have .085 clearance with my setup now, and would like to get the Yella Terras to quiet the valvetrain down. Per Paul @ Thunder Racing's advice, I shouldn't go below .080 clearance.
I know the only way to know for sure is to retest P/V after the rocker install, but I don't want to spend the money in the first place only to find out I don't have enough P/V.
Old 05-29-2003, 08:42 PM
66ImpalaLT1's Avatar
Default Re: Will Yella Terras reduce my P/V by more than .005?
I wish I had a dial indicator, then I could possibly measure the lift difference off the retainer.
I put a set on a couple weeks ago but my cam is mild and I have stock heads.
Eric
Old 05-29-2003, 09:58 PM
CamaroSS_2002's Avatar
Are your heads milled out of curiousity? I have a larger cam and my heads are not milled at all and I am pretty sure I won't have to worry about P/V clearance but I dunno?
Old 05-29-2003, 10:27 PM
verbs's Avatar
My heads are milled .010
