idling problem
idling problem
Just put in my 233/239 and... it wont find idle.... how big should i drill out the throttle body flap. When i hold the idle to 700 rpm it idles nicley but it just stalles with the hole in it now
Stop drilling. Adjust the blade with the set screw. After each adjustment perform a TPS reset. To do the reset turn the key to start but, not run. Unplug the TPS. Turn off the car. When you turn it back on you will have to reset the code with a scan tool.
You do have tuning software or someone to tune it? Idle tuning is a pain, I've been at it for weeks and still having problems with surging/hunting.
yhea im goin into the tuner on sept 11... ill try that other **** the first person suggested, i guess thats always reversable... would it work if i grabbed my frends tuner and put the idle up like 3-400 rpm?
