Dark Phoenix Risen Again
6 Month Project RUNS!
I thought I'd just edit this post to say that I fired up the car tonight and I got full oil pressure reading needle reads just over center at idle. The cam sounds absolutely AWESOME! I'm getting the radiator flushed tomorrow and I'm going to change the oil as well. I will post a video clip as soon as I locate my digital camcorder. I just want to take the opportunity to thank EVERYONE for all their help and input in my project! This would have never happened without LS1tech. Once again thank you so much and hope to see everyone on the streets
Before: Stock
After:
LS6 Melling HVC Oil Pump
LS2 Double Roller Timing Chain
Comp Cam 224/228 .588 lift cam
Comp Cam Hardened Pushrods
918 Beehive .600 Valvesprings
243 casting LS6 GM Heads
Ported Polished and Epoxied Throttle Body
Hedman LT Hedders
3" Tru Dual Exhaust w/ X Pipe (no cats)
Bullet Mufflers
Fresh Gaskets and Seals
Full Smog/Emissions Removal
UNTUNED and runs
Before: Stock
After:
Hedman LT Hedders
Bullet Mufflers
UNTUNED and runs
