LQ9 crankshaft in an 00 ls1?
Old 09-06-2007, 11:32 AM
ace68's Avatar
Default LQ9 crankshaft in an 00 ls1?
is there any differances that would preclude the use of an lq9 crank in an 00 ls1? I have a block that I could use and a crankshaft in good condition I also have rods just need some pistons.
the flywheel looks like it will bolt right up but is there a issue with useing one in a fbody with a t-56?
and I did use the search but only found info on an auto.
Old 09-07-2007, 09:21 AM
ace68's Avatar
anyone have any info on this?
Old 09-07-2007, 11:03 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
From what I've heard is that it won't work properly. I'm not 100%.
Old 09-07-2007, 11:09 AM
5.3LJimmy's Avatar
I know the earlier 6.0 cranks had a flange that stuck out further where the flywheel bolts on, but I don't know if the newer ones are the same.
