6.0 iron block?
6.0 iron block?
Well time for a rebuild. My questions are: how much nitrous can the 6.o iron block take bored to 4.030? Might just use the same cam ( trex cam) no stroker. crank will be kept stock. Might consider hovering compression around 12.0 to 1. Gonna use stock ported heads. Any rocommendations
30 thou is *** all. a cast iron block wont be your weakest link... the nitrous will blow your gaskets or your pistons first. personally 30thou is about what id take a motor out too, maybe 40thou. seen other cast iron engines above 40thou have heating issues, 30 will be fine mate
