comp cams xr269hr pushrod length ?
Old 10-16-2007, 06:46 AM
bogstock's Avatar
Default comp cams xr269hr pushrod length ?
Hi Guys
What pushrod length do i need to run with xr269hr 216/220 525/532 114
Are ls6 springs good for this cam
Thanks Paul
Old 10-16-2007, 08:12 AM
Camaro01SS4life's Avatar
Pushrod length should be the same as stock if you are using stock heads and gaskets, which is 7.400 in length...As far as springs go, the LS6's will be fine...Depending on the year determines how much lift they can handle...The 01 springs(I think are blue) can handle up to .540 lift while later LS6 springs(Green and orange) can handle around .580...
Kev
Old 10-16-2007, 11:01 AM
PREDATOR-Z's Avatar
Originally Posted by bogstock
Hi Guys
Thanks Paul
02+ LS6 or LS2 springs are perfect.
7.400 pushrods will be fine.
