How in the hell does that not need fly cut and my trq v3 needs to be? I am running the ls6 stg2.5 heads but they are 64 cc heads and it less duration then the ms4?
as long as your lsa is 111 and up if you are on stock heads then no flycutting. Make sure you have good dual springs, Patriot and PRC are what I use on my cars.
it does have stock heads and i was going to order the 111 or 112 because i plan and spraying the car with a small shot
