Stock 6.0 + 200 shot...
Anyone have experience with a stock lq9 on spray? It'll be a stock motor with a set of valvesprings, cold-air intake, larger injectors, and full exhaust. On a dry 200 shot with a dyno tune. Through a built th350, ~4000 stall. What kind of power should it be able to make at the wheels?
150 shot here on a stock piston/rod/crank 6.0L, i did put in a set of ARP rod bolts and a ls2 chain, no problems
i would never use a dry kit,,, id convert it to a wet kit then you know for sure your getting enough gasoline with the nos and run it on the rich side
