Another Heads/Cam ?
Old 12-14-2007, 03:57 PM
tboysen00's Avatar
Default Another Heads/Cam ?
Heres the deal, going to do a heads and cam packaged this spring but I'm getting the cam for christmas so I need to make up my mind now.
Either a reverse split .600/.570 230/226 on 113 custom grind comp cam, and a set of heads(not sure which ones so someone could chime in and let me know what set would work best)
VS
MS4 and Stg 1.0 LS6 Heads or stg. 2.5. (do i need the ls6 oil pump, and should i go with stg 1 or 2.5)
will be a weekend warrior. its a M6 2000 ws6 with full exhaust, ported tb, lid, and a double roller timing chain, ls6 intake and maf.
I had the reverse split in my old car and made 398 rwhp cam only. I liked it but not sure if it's a good cam for heads. The Texas Speed setup is prolly cheaper. LMK thanks Troy
