ValveTrain Problems! Help!!
Old 12-19-2007, 11:31 PM
ezrollin's Avatar
Default ValveTrain Problems! Help!!
With the valve locks off:
the seats, retainers, and springs stick BAD.
The spring sticks to the retainer and valve seat BAD.
It takes ALOT of force to get the spring off!!!!! I mean, I have to literally beat it with a hammer to get the spring off!
The inside spring is Longer (double valve springs), is this okay? (not worried too much)
A few springs pulled the seat and seal with it.
When we try to hammer the seals back on, it just disintigrates. Using a 9mm - 13mm.
Please help, I'm trying to help my friend install this HPE S cam.
Thanks alot.
Old 12-20-2007, 12:40 AM
PREDATOR-Z's Avatar
1- Change all the seals
2- Don't hammer just tap with a long socket that barely clears the valve stem diameter, you'll feel when they are seated.
3- If seats have deep marks on them, they should be changed as well.
Old 12-20-2007, 12:50 AM
ezrollin's Avatar
so should we be worried about everything "sticking"?
this girl that knows her stuff said that we should be worried about our seals, retainers, springs sticking BADD.
