Valve Seals
Valve Seals
Installing my patriot gold kit I pretty much destroyed some of the valve seal spring lookin thing. I want to go back through and check all of them and replace them as needed, the only set of valve seals I can find are the comp viton ones, are these the same as the patriot ones?
And I'm going to use a 1/2" deep socket to put them on, is that correct?
