Decision...Heads and Cam
Ok, I thought that I had made up my mind on what H&C combo but I like to change my mind alot. The first combo I was looking at is Trick Flow:
http://www.trickflow.com/partdetail.asp ... toview=sku
The next combo was with a Comp Cam:
http://www.ls1build.com/LS1-Horsepower/Stage3.asp
and RHS heads:
http://www.ls1build.com/LS1-Horsepower/Stage5.asp
Another combo is the Edelbrock 2218 LS1 Cam which is brand new and will be released Jan 18th and the RPM XT heads:
http://www.edelbrock.com/automotive_new ... _rpm.shtml
Edelbrock claims 488 hp with this combo with NO computer tuning on a stock LS6.
I have looked at a number of other H&C packages like Texas Speed and Thunder Racing. What do you guys think? Are there any other good combos that I am over looking?
and RHS heads:
If you have the money you really can't go wrong with the trick flows or a set of AFR's. And you can always spec out your own cam but the one with the trick flow kit looks very similar to the one I had ground after spending countless hours researching it. Your link is to a ford 5.0 kit but I'm guessing you really want this one:
http://www.trickflow.com/partdetail....0&autoview=sku
