dirty intake
Old 01-05-2008, 05:31 PM
Ricky_GD's Avatar
Default dirty intake
Hi guys, just a quick one, i have just taken the intake off my ls1 to have it painted and notice that the intakes in the head were oily/fuely (dirty) is this normall or should they be clean? also what can i clean them out with?
thanks
Old 01-05-2008, 05:56 PM
Lt1Porsche's Avatar
Its normal. Get a catch can setup to reduce the blow by. You could clean it with some carb cleaner but it wont make a bit of difference. JMO
Old 01-05-2008, 05:59 PM
Ricky_GD's Avatar
cool thanks!
Old 01-05-2008, 08:35 PM
1badA3Z's Avatar
Yea its no biggie,wouldnt worry to much bout it!
Old 01-05-2008, 10:12 PM
1Hotbird's Avatar
If you want run a catch can then seafoam the engine! That should clean it up. But its normal nothing to worry about!
Old 01-07-2008, 09:05 AM
radkon's Avatar
If you are going to clean it use brake cleaner, carb cleaner leaves an oily residue and may discolor the plastic (it did on mine)
Old 01-07-2008, 02:46 PM
Ricky_GD's Avatar
Thanks buddy i was just about to asked if brake cleaner was ok ... cheers
