Found my oil consumption issue!
Old 01-06-2008, 07:45 PM
1BADAIR's Avatar
Default Found my oil consumption issue!
This one is so bad there is oil leaking out past the gasket on the header
Old 01-07-2008, 10:58 AM
Restricted User
2001 Pewter WS6's Avatar
What was it??? The valves???
Old 01-07-2008, 12:06 PM
Cole Train's Avatar
yeah are the valve seats bad? or the seals?~cole~
Old 01-07-2008, 12:22 PM
brad8266's Avatar
I have the same problem and I believe it is the valve stem oil seals. All 8 of my plugs have oil on them and it isnt the pcv since I disconnected it. And 8 bad piston rings is highly unlikely.
Old 01-07-2008, 05:27 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Rocker bolts? That's a possibility.
Old 01-07-2008, 06:42 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
I'd guess valve stem seals.
Old 01-07-2008, 08:20 PM
1BADAIR's Avatar
guides are toast so the seals are too
