5.3 heads on a 6.0 block
Old 07-02-2003, 09:18 PM
algws6's Avatar
Default 5.3 heads on a 6.0 block
is this possible and if so where can a get a 6.0 block at a good price. i was thinking of running this combo with a G5x2 and my TEA stage two heads. any opinions?
Old 07-02-2003, 11:33 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Default Re: 5.3 heads on a 6.0 block
Yes, it is indeed possible. They will bolt right on. Check out our truck classified section, or search for "Valvegod" (Shaun) in the classified section. He can locate stuff like that no problem.
6.0L iron block is known as an "LQ4" block.
Tony
Old 07-03-2003, 08:32 AM
Dumb Ass Vette Moderator
ls1290's Avatar
LS1Tech 20 Year Member
Putting heads with 'smaller' chambers on blocks with bigger bores is fine; 5.7L or 5.3L heads on a 6.0L block. One can run into quench problems putting larger chambered heads on smaller bore blocks if the heads are not machined to compensate.
