What should oil look like after first 500 miles of break in?
Old 07-02-2003, 11:00 PM
7 Second Club
Phil99vette's Avatar
Default What should oil look like after first 500 miles of break in?
My motor has roughly 500 miles on the motor and wondering what should the oil look like when I do the oil change? I assume with the ring, cylinder wall and bearing break in wear the oil isn't going to be exactly clean. What should I expect?
Old 07-02-2003, 11:31 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Default Re: What should oil look like after first 500 miles of break in?
Depends on if that first 500 miles is at Wide Open Throttle
Most of the time, its typically still original color, with possibly some slight metallic in it, at only 500 miles.
Tony
Old 07-03-2003, 10:51 AM
canadian z28's Avatar
as long as it doesn't look grey your o.k.
