View Poll Results: Dart Springs or Duals
Stay with the Dart springs.
2
40.00%
Replace with new PRC Duals.
2
40.00%
Replace with my current used PRC duals.
1
20.00%
Voters: 5. You may not vote on this poll
Use stock Dart Valve Springs or go to Duals?
Old 01-12-2008, 01:28 PM
Bill Bowling's Avatar
Default Use stock Dart Valve Springs or go to Duals?
I have a new set of Dart 205 heads with the stock Dart valve springs. My cam is a .595. Should I replace the springs with new duals or should I use my current used PRC Duals? They have about 12K on them.
Bill
Old 01-12-2008, 01:58 PM
vettenuts's Avatar
The PSI 1511 valve springs on your Dart heads are superior springs to the PRC's, have better surface treatment and will rev higher. I wouldn't use anything else unless they won't support the lift. Also, the titanium retainers on your Dart setup are only 6 grams. Check out Katech's web site, they tested a ton of springs that they considered for their 427 builds, they selected the springs you are thinking of removing.
Old 01-12-2008, 02:21 PM
JPH
JPH's Avatar
+1 for that answer vette.
Old 01-12-2008, 04:27 PM
Thanks guys. Will these springs work with my cam's lift?
Bill
Old 01-12-2008, 04:39 PM
DaveX's Avatar
Yes they are advertised to be good for .620 lift. I have them on my car and they haven't been on long but no problems so far. My cam is .588/.595 lift.
Does anyone know where to buy a replacement set of these springs? I would like to have a set for when I eventually need to change them but can't seem to find them for sale anywhere.
Old 01-12-2008, 04:46 PM
JPH
JPH's Avatar
Bill
yes sir.
Old 01-12-2008, 05:06 PM
vettenuts's Avatar
CV Products carries them. There is also a more expensive "ML" version that has additional surface treatment for "Max Life".
Old 01-12-2008, 05:33 PM
DaveX's Avatar
Cool, thanks for the info.
Old 01-14-2008, 04:45 PM
I think I will just use the stock Dart springs. Thanks everyone for the info.
Bill
Old 01-14-2008, 05:11 PM
405HP_Z06's Avatar
Bill
Excellent choice,
