X1 Vs G5X2 Cam...
Old 07-04-2003, 09:41 AM
JoSeY's Avatar
Default X1 Vs G5X2 Cam...
I currently have GTP stage 2 heads with the Rev dual valve springs so lift is not a concern....I am currently running the MTI X1 cam and LOVE IT. Has anyone switched from the X1 or similar 230/227 .591/.581 114 to the G5X2 and what gains did you see...is it worth it? or am I wasting my time??
Thanks,
Old 07-04-2003, 11:57 AM
JoSeY's Avatar
Default Re: X1 Vs G5X2 Cam...
Come on...TTT
Old 07-04-2003, 12:12 PM
Formerly 4mulaJoe
LS1x2's Avatar
How much are your heads milled? I'd have that same setup now if my GTP's weren't milled .030. Need some deep valve reliefs to have PTV clearance.
Old 07-04-2003, 12:20 PM
JoSeY's Avatar
Hmmmm...have to check with Craig but I believe they are milled.....if they're milled no way huh?
Old 07-04-2003, 01:13 PM
JF WS6's Avatar
Thanks,
I personally have witnessed an increase of 20+HP to the rear tires... I'd say you wouldn't be wasting your time. You can skate by on .015 shaved off the head (probably 75 thou clearance on the intake side) but at .030 you'll definately need valve reliefs cut. Even if you were milled at .015 I'd check the clearance anyway to make sure.
Old 07-14-2003, 03:55 PM
Billiumss's Avatar
Any new info?
Quick Reply: X1 Vs G5X2 Cam...
