what injectors should i use?
Old 01-23-2008, 11:21 AM
geovett's Avatar
Question what injectors should i use?
i'm stalling Ms3 cam with ported heads, 3500stall on my o1ss..ls7 lifters.............what injectors will best FIT my setup...NEED HELP..!!!!
Old 01-23-2008, 11:24 AM
99mongooSS's Avatar
36rs so you have some room to grow
Old 01-23-2008, 12:59 PM
BLACK2001SS's Avatar
stock on a 01 should be fine cam only, heads then your probly getting close
Old 01-23-2008, 01:08 PM
Apollo0526's Avatar
What kind of injectors do you guys recommend, bosch, ford, delphi, ect...
Old 01-23-2008, 01:28 PM
99mongooSS's Avatar
I use the racetronics injectors>
Old 01-23-2008, 01:38 PM
PREDATOR-Z's Avatar
30lbs SVO, they are Bosh
Old 01-23-2008, 01:41 PM
Apollo0526's Avatar
Thanks
Old 01-23-2008, 01:45 PM
HAMRHEAD's Avatar
30# SVO injectors are fine.
Old 01-23-2008, 02:01 PM
geovett's Avatar
Unhappy
i just bought some brand new 36# bosh 4 $250 bux was that a good deal???
hey thanx for all the good info.............
Old 01-23-2008, 02:12 PM
trukk's Avatar
I'd love to get some concrete recommendations on this (i.e. part numbers/links), rather than 36#ers
I'm in the process of getting together all the parts for a cam swap. I'm at 94% IDC at WOT right now, so I know I'll need new injectors with the cam I've got spec'd out. Being the **** retentive nervous nellie that I am, I wanted to get some flow matched injectors, so I can keep my engine as reliable as possible (car is a Daily Drive that I also runa approx 6 HPDE road course weekends in a year, so reliability is high on the priority list for me). Finally I like to buy this stuff only once, so I'd like to spec something out that will work now, and work down the road. The max I ever see this car going to is 475ish rwhp, N/A.
With the above in mind, after looking around, I was planning on going with Flow Matched Ford SVO 30#'ers (i.e. Red Tops, PN:M-9593-B302F), unless someone can give me compelling reason not to. There did not seem to be a lot of choices on flow matched injectors in the 36ish # range.
Links to some sponsors that carry the flowmatched SVO's:
http://www.texas-speed.com/shop/item...d=222&catid=10
http://www.livernoismotorsports.com/product.phtml?p=304 (buy 2 sets of 4?)
http://www.sdparts.com/product/M-959...ctor8Pack.aspx
Hope this helps,
Chris
Old 01-23-2008, 09:06 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I had SVO 42s with my MS3/PRC 5.3 combo. They were only at 57% duty cycle at 6800 RPM
Old 01-23-2008, 09:09 PM
98Camarod's Avatar
I got the 42s from speed inc. I'm not sure what brand they are, but they get the job done.
Old 01-23-2008, 10:01 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We do a lot of the 36# FAST injectors in our setups, they are priced right & are CARB approved! For the money the FAST 36# injectors are really hard to beat!
http://www.texas-speed.com/shop/item...d=670&catid=10
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-24-2008, 07:58 AM
CodeRed2000SS's Avatar
fast 36's has my vote too
