cam retention plate
Old 01-24-2008, 04:44 PM
forcd ind's Avatar
Default cam retention plate
is the cam plate reusable? i noticed it has a seal, didnt know if the plate can be reused, or if the seal is replacable-thanks
Old 01-24-2008, 05:06 PM
vettenuts's Avatar
Seal is not replaceable, inspect it for cracks or anything that would cause a leak as it seals the lifter galleries. The bigger issue is typically wear on the plate. I just bought a timing set with a Torrington bearing for this reason. Vinci has some photo's of the wear that can occur. I am also replacing the plate. Be aware that the plate design and attachment bolts have now changed and you can't re-use your original bolts if you buy a new plate. The new plate is countersunk and the bolts are flat head.
Old 01-25-2008, 06:53 AM
forcd ind's Avatar
thanks for the reply-did you get the plate from gm, or aftermarket
Old 01-25-2008, 11:19 AM
vettenuts's Avatar
GM. I started a thread on the cam plate on 12/17, lot of good information in there from SDPC.
