trick flow kit. which cam?
i bought a Trick Flow 515 HP GenX Top-End Engine Kit and the supplied cam is
228/230 585/585 should i stick with this cam or run something else? if i run something else what should i run? all info is appreciated.
it a 1998 trans am a4 342 rear gear. i have a lid. pacesetter race headers. true dual's with x pipe and single chamber flowmaster's. lower of engine is stock. i just want a fast street car that puts up some nice numbers at the track.
ran a 13.5 et before the trick flow kit.
Hey guy's I just purchased my 02' SS and was wondering about the same kit like smokeyrider05. I saw it in the summit racing magazine and was thinking about doing this package later on down the road. So you guys recommend it?
thanks guys, i think i'm just going to just stick with it. now what else would anyone think would be needed to get my car into the 11's?? i ran 13.5 before trick flow kit.
Hey MM98 pm me the results after you get your car dynoed, Glad to hear your happy with yours. As you know I will be switching tfs cams later on because of the d1sc I just purchased.
That setup should definately get you in the 11's with a good tune. And that is a nice "power under the curve" cam which should be great for the street. I don't see an intake on your mod list, I would try to at least come up with an LS6 intake before install time.
