Head gaskets
Old 02-02-2008, 11:37 AM
o-ss-kar's Avatar
Default Head gaskets
I need help asap,
Is it ok to use 6.0l head gaskets on a stock 5,7l ls1 ?
Thank you.
Old 02-02-2008, 11:54 AM
Ls1Gummi's Avatar
Why would u do that??
Old 02-02-2008, 12:04 PM
ae13291's Avatar
yea why??? those might be thicker gaskets that would cause you to loose some compression!
Old 02-02-2008, 12:44 PM
o-ss-kar's Avatar
reason is, I live in Iceland and im on a limited place, and everything is open now and I need to finish it before monday.
I got 6.0l head gaskets but my engine is 5.7.
so is there gonna be a problem for me ?
Thanks
Old 02-02-2008, 02:41 PM
vettenuts's Avatar
Absolutely not. I am running them right now because the Dart heads have a little wider chamber. In actuality, the are a little thinner as well (0.051 vs. 0.054 for 5.7) as I recall. You will be fine with them. Gunnar from Patriot used to ship them with every head set as well.
Good luck with the install.
Old 02-02-2008, 02:46 PM
JPH
JPH's Avatar
Originally Posted by o-ss-kar
I need help asap,
Thank you.
it's ok, but SCR will decrease a little with the added volume from the larger bore gasket.
