1.85:1 Pro Magnum roller rockers
Old 03-04-2008, 10:15 PM
Upgrade's Avatar
Default 1.85:1 Pro Magnum roller rockers
Hey guys,
Has any one installed these to an 03 GenIII Ls1 GTO #241heads std,std cam,comp cams #850-16 High energy hyd roller lifters std replacement,std GM head gaskets . If so did you use std length 7.400 pushrods. Having problems with setting lash. set as per comp cams tech info site and posi-locks hitting baffel in rocker cover.Set lower and loosing compression from valve not seating correctly.
Questions from across the Pacific in Australia thanks for any info in advance.
Quick Reply: 1.85:1 Pro Magnum roller rockers
