ls1 push rod ??
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Moving to internal section.
Your bottom end will have no difference in deciding on your pushrod length. I am not sure if the MS4 has a smaller or larger basecircle, but I think it is gonna be either a 7.400 or 7.350 Depending on what your heads are milled and the gaskets you are running. I would try searching under MS4 on the site and see what you can find. I know this has been asked numerous times before.
