MS4 Question
MS4 Question
i wanted to buy an MS4 cam but dont really know much about cams. Ok i have a 99 T/A A4, mods are hooker L/T's and borla catback exhaust and gettin a F.A.S.T intake. if i get the MS4 what other upgrades do i need and what heads should i get.
Thanks
Thanks
no prob u will love that cam i did.. made great power.. but u have to run a stock head ie stock valves and no milling.. to get it to clear and even then its tight but get rod bolts.. trust me i just built a motor because i didnt it was the next thing on my list
So your motor went cuz u didnt put arp rod bolts and u where revvin the **** out of to get all the power out of the cam right? I am also looking into this cam, but i really dont want to go through the hassle of doing rod bolts...
Need a big stall, gears, Poly motor mounts, Poly trans mounts LCAs, relo brackets, poly rear sway bushings, some serious tuning. That doesn't include cam swap parts.
Heads as mentionned 243 stage 1 if no flycut
What is the purpose of your car and what do you wish to achieve?
