LQ4 (new guy ?'s)
LQ4 (new guy ?'s)
Hello I am planning on building a 6.0 lq4 its going into a 87 RX7. Most likely have a 4l60 behind for now budget reasons. Any advice on a mild cam for the street along with heads keeping in mind price.
Basic stock lq4 short block, I want to keep the compression low so i can run 87 gas and willing to sacrifice HP car being very lite 2,600 lbs. Cam advice LS1, LS6, Z06 possibley aftermarket too.
Intake Ls1, Ls6 ?
Heads? LS1, LS6, aftermarket cheap.
The ls series is new to me so any advice can be helpful I am more familiar with gen 1 blocks but out with old in with the new. I am not trying to build a 500 horse motor something slightly mild and reliable to drive dailey to work in the summer and I feel this is a cheaper route than used LS1 motors on ebay for 2,500 or more. Thanks guys
Intake Ls1, Ls6 ?
Buy this book from Amazon or your local bookstore. Definitely worth the money if you're starting new with Gen III and IV motors.
http://www.amazon.com/How-Build-High...6404934&sr=8-1
6.0's with stock 317 heads are designed to run all day on 87 octane fuel without hurting them. Before you blindly jump in and screw up a good engine do a lot of reading first. Killing compression for fuel economy is old crap that no longer applies to todays modern fuel injected engines.
