Who is getting away with less than .080" PtoV intake clearance?
Cam is 228/232 114LSA 112ICL. Stock gaskets with a few thou off the heads. I put in Caddy lifters, checker springs, and bolted down the head with couple of bolts and the used gaskets. About 5* ATDC it gets around .073". Would any of you feel safe running that clearance?
So nobody checks the clearance? I see lots of replies to post where people ask if a certain cam will have a clearance issue, and people reply with stuff like "Ah that should be fine." But nobody that replies ever specifies what clearance they had with their cams
I am running some really close tolerances. I can call my installer and get the exact specs. Chuch @ HPE originally put in my Mega Death and said there were no clearance issues. Turns out it is pretty close and with my Patriot heads I am a little better off. I have yet to have a problem and I run the car really hard. But I can afford to fix it if it blows.
