Does top end cleaner go into the MAF?
Old 07-30-2003, 06:35 PM
Freak's Avatar
Default Does top end cleaner go into the MAF?
or am I supposed to take that off and run it with no MAF and just spray into the TB?
thanks
Troy
Old 07-30-2003, 06:52 PM
DangeRuSS's Avatar
Default Re: Does top end cleaner go into the MAF?
Do not run it through the MAF. You need to disconnect the MAF and run directly into the TB.
You will also need ot clear the MAF code cause it will set the SES light.
Old 07-30-2003, 08:56 PM
Freak's Avatar
thanks!
Old 07-30-2003, 09:09 PM
Danny2tek's Avatar
I sprayed it straight into the TB and got no SES, it was a bitch though it kept wanting to stall...a little advice keep it in for a while before firing her up
Old 07-30-2003, 09:15 PM
Freak's Avatar
are you talking about when it says to shut down and lat it sit for 15 min? your saying i shoudl let it sit longer?
