Oil pressure is dropping {HELP}
Old 08-04-2003, 04:37 PM
johnster's Avatar
Default Oil pressure is dropping {HELP}
When i am diveing around it is fine.When i give it some gas and the RPMs get to about 4000 the pressure drops to like 20 pounds so i let off of it.why is the oil pressure dropping like that? It just started do it two days ago. HELP
Old 08-04-2003, 05:19 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Default Re: Oil pressure is dropping {HELP}
Have you check the oil to make sure it's not low?
Old 08-05-2003, 07:50 AM
robertbartsch's Avatar
...could be a bad oil pump ...very common in these engines...
Old 08-05-2003, 08:01 AM
DSG
DSG's Avatar
Hindsight being 20/20 I noticed this problem on mine. Needless to say I spun a rod bearing due to the oilpump failing. Like robert said, in the 97-00 LS1's it very common.
Old 08-05-2003, 11:44 AM
dug
dug's Avatar
Mine does that when its low a quart of oil. Check your oil level.
Old 08-05-2003, 02:58 PM
johnster's Avatar
Thanks guys
