5.3 heads and big cam
Old 05-03-2008, 09:36 PM
tripblackls1's Avatar
Default 5.3 heads and big cam
so ive bought a set of 5.3 heads and im going to have them taking down to 59 cc and ported
im looking for a cam and i really want to use a ms4 but having a hard time finding one for my price
i have found a bunch of custom cams that are larger than ms4 and i was wondering how big can i go with these heads
i know the ms4 need flycutting which im willing to do but are some of these cams im looking at to big for the head (ie as to much flycutting of pistions)
Old 05-04-2008, 02:31 AM
LS1C5Vette's Avatar
Is this your DD?
Old 05-04-2008, 06:57 AM
venom ws7's Avatar
MS4,MS3,Trex,LGX4
You need to flycut with any of these cams.
Check Tr trak cam its an awesome not huge cam but with 59cc the car will fly and very good for daily driven car check the vid in mu sigs.
or talk to PartickG or PredatorZ for custom cam.
Old 05-04-2008, 07:37 PM
camaroIroc's Avatar
is an ls2 stock cam too much for these stock 5.3 heads? (.500 intake, .500 exhaust)
Old 05-04-2008, 08:57 PM
CALL911's Avatar
MS3 you won't have to flycut with. TSP sells the MS3 with the 5.3 heads as a combo with no reccomended flycutting.
Old 05-04-2008, 09:09 PM
Cam72aro's Avatar
Originally Posted by venom ws7
MS4,MS3,Trex,LGX4
No flycutting with the trex either. Designed for stock head without flycutting.
Old 05-05-2008, 07:05 AM
black00ssFL's Avatar
If he didn't get the heads specifically from TSP for use with the MS3....he will have to flycut (they recess the valves slightly). And yes...any of the cams mentioned will have to have the pistons flycut with the 5.3 head. It's a stock head...but the chamber is smaller and clearances are closer than a stock LS1 head.
Old 05-05-2008, 07:51 AM
teke184's Avatar
"so ive bought a set of 5.3 heads and im going to have them taking down to 59 cc and ported"
he's having the heads milled guys....so all those cam you say will fit...WON'T
i gues i'm curious why you seem to think you need to go so big on the cam? why not spend the money on better heads, a better custom cam...and you'll make the same if not more power.
big is not always better
as for:
"is an ls2 stock cam too much for these stock 5.3 heads? (.500 intake, .500 exhaust)"
you must be kidding right? that's such a small cam (if it even works on the ls1) its not worth the time and money to swap it out.
most of the cams these guys are talkin about are .600-.645" lift.....
Old 05-05-2008, 08:55 AM
2000KnightRider's Avatar
Word. I'd say get a good set of heads like TEA Stage 2.5 5.3L heads and get a good cam spec'd out by Predator-Z. Let him know what range you want your power to come in at and if its going to be a DD or weekend warrior.
Old 05-05-2008, 11:41 AM
Jon@Texas-Speed's Avatar
We can CNC port the heads, cut the valvejobs, and deck the heads if you would like. If you want, we can also put on a set of PRC Dual springs to support these larger cams you are wanting to run. We can set you up with a package with everything you will need to complete the install from the cam, pushrods, gaskets, timing chain, oil pump, ect. We can always spec you a custom grind cam to match your combo if you prefer. Give us a call or shoot me a PM and we can take a look at some pricing and go over the setup!
Jon
Texas Speed & Performance
Old 12-29-2010, 07:52 AM
ryany's Avatar
Would a Trak cam work with the TSP 5.3 2.5 59CC Would i have to fly cut?
Old 12-29-2010, 06:04 PM
Captain Double Post
BOBS99SS's Avatar
Agree if your getting heads you don't need such a big cam,is this a dd or track car,I have the ms4 and I like it but I don't dd the car ,
