ls1 crank
Old 05-19-2008, 01:37 PM
2000fbcam's Avatar
Default ls1 crank
okay i have what might seem like a repetitive question. I have a 1998 z28, bone stock. My question is, what is the max amount of power that a 98 ls1 crank can handle. Ive heard anywhere from 400-1000hp. I would like a no B/S answer, no what if or maybes. What can it handle.
Old 05-19-2008, 01:57 PM
ss.slp.ls1's Avatar
Your going backwards...you pick your parts depending on your hp goal, not pick you horsepower depending on your parts.
Old 05-19-2008, 02:22 PM
david vericker's Avatar
The LS1 crank is the strongest stock bottom end component. Unless you intend on exceeding 1000 HP I wouldn't worry about it. The stock rods (rod bolts) and pistons will fail long before the stock crank will let go.
Old 05-19-2008, 09:05 PM
Shawn @ VA Speed's Avatar
the stock crank is a very good piece.we pushed one to 1033rwhp
Old 05-19-2008, 10:12 PM
Restricted User
socmguy's Avatar
The stocker is good for a solid 900 HP
