Serious Bucking Idle Surging after SSF Converter Install.
The car is a 1998 Z28 42000 miles auto, Mods are Super Street Fighter converter, 4.!0 gears, ASA cam, 226 236 110 lsa, Long tubes, car ran great with all the items above but different converter, Now with this converter after running it kinda hard, or sometimes just in reverse the rpms will move up and down from 800 to 1500 to 500 sometimes fall on its face, I would like to try and correct this before tomorrow because im going to the track and I know this issue is going to effect me at the burn out box, I have included my current tune file for someone to take a look at, I have adjusted the idle several times, please any help is welcome, thanks. I have posted this on other forums including Hptuners. if anyone can help please do so.
Also after racing and coming to a stop my rpms go from 1500 to 500 sometimes shut off, or although it's bad to start a car with ac on if I do forget to turn the ac off before starting the car, the car will just shut off and then I turn the ac off and start the car again. I can't use the ac sometimes when the car is in reverse or it shuts off as well. So please if you run into what your problem is let me know. I Have posted my tune file asking for someone to look at it but no dice.
