Gaskets/Bolts Needed For Cam Swap
Old 05-27-2008, 12:07 PM
killerbeez's Avatar
Default Gaskets/Bolts Needed For Cam Swap
Ok, this should be an easy search because I've seen this exact topic before I just cant find one through search
anyways, for my cam swap/overhaul I have these:
cam
springs
pushrods
ls6 ported pump
ls2 chain
Now I need these:
Headbolts
Head Gaskets (cause i'm porting ls6 heads also right now so do I order ls6 head gaskets or ls1? or are they the same)
Crank Bolt
I'm also putting on headers so just header gaskets right? or do I need header bolts too (are they one time use?)
Now does anyone have part numbers for these? Is there anything else I need like do I need a timing cover or anything like that? (NOTE My car is a 98)
THANKS for any help
Old 05-27-2008, 01:17 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
We've got everything you need including the bolts and gaskets for your swap, and competitive prices too! Let me know if I can help, and we'll be glad to put together a quote with all the parts you need to do the job right
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 05-27-2008, 02:19 PM
killerbeez's Avatar
hmmm, I may call you guys, my dad has a shop so he'd get wholesale, that's why I was gonna piece it together on just the few remaining parts, but it may be easier to call ya guys
