double roller ?
Old 06-07-2008, 05:15 PM
blazerls1's Avatar
Default double roller ?
I'm getting ready to buy a double roller timing set,and am having trouble finding the one I want.I want a 1 piece crank gear instead of the 2 piece gear I see everywhere.Does rollmaster still offer one?I bought a rollmaster CS1160 for another motor I have,and the picture from byunspeed was a 1 piece,but when it arrived,it was 2 pieces.Just seems 1 piece should be stronger than 2 pieces.
Old 06-07-2008, 08:12 PM
Halloran's Avatar
Hmmm...guess I'm not sure what you mean by a single gear. You kind of have to have two gears. The larger sits in front of the cam and the smaller sits in front of the crank. I've never seen a single gear that would compliment both...if that's what you mean. Otherwise you'd end up with an upside down shaped gear.
Old 06-07-2008, 08:54 PM
eallanboggs's Avatar
What brand was the timing set you got from Byunspeed?
Old 06-07-2008, 08:58 PM
rhubar's Avatar
i thing the one piece crank gear and pump drive are only for single chain setups.
Old 06-08-2008, 08:28 AM
blazerls1's Avatar
1 piece =has the oil pump drive part made on the crank gear.all 1 piece.2 piece has the crank gear then the oil pump drive seperately.The 1 piece is exactly like a stock crank gear,but is a double timing gear..
Old 06-08-2008, 11:58 AM
vettenuts's Avatar
The Crane setup I believe is a one piece crank gear.
