how to reinstall stock rockers?
Old 06-20-2008, 04:24 PM
bird2002's Avatar
Default how to reinstall stock rockers?
I changed the pushrods, some bent valves and springs. Now I need to figure out how to correctly torque down the rockers. I set it up so cylinder 1 is at top dead center, now were do i go from there?
Old 06-20-2008, 04:29 PM
LSX Mechanic
Damian's Avatar
Clean up the rocker studs, throw some loctite on them, TQ straight down the line 22 ft lbs. Spin the motor, recheck TQ. Done.
Old 06-20-2008, 04:39 PM
bird2002's Avatar
you dont have to do cylinders in order 1,2,7,8 spin motor then 3,4,5,6
Old 06-20-2008, 04:40 PM
5_02ls1's Avatar
what he said be sure to rotate the engine a few times....sometimes they loosen up after the engine is spun
Old 06-20-2008, 04:41 PM
5_02ls1's Avatar
Default n
no shaft mount rockers just tork down
Old 06-20-2008, 04:49 PM
bird2002's Avatar
sweet
Old 06-20-2008, 05:46 PM
BriancWS6's Avatar
Exactly.
I usually rotate and re-check a few times because of my OCD, but they've always been torqued correctly from the first pass in my experience.
Old 06-20-2008, 06:18 PM
Grimes's Avatar
little bit of advice...if you soak your lifters in oil first, don't just torque the rockers right to 22. Snug them down with a small ratchet and stop when you start feeling resistance...you'll hear them bleed down....then after a little, tighten them some more....ect....until you bottom the head of the bolt out. Then tighten to 22 lbs....rotate...then check 22 again....
Old 06-20-2008, 09:05 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Yea one of the few things I loved over my old LT1 :love:
Old 06-20-2008, 09:47 PM
vettenuts's Avatar
Here is the correct GM procedure.
Old 06-20-2008, 11:37 PM
bww3588's Avatar
yes, do NOT just torque them down in a line. do it as per the GM manual above.
