does ls1/ls6 motor come with oil pan?
I need to know if an oil pan is included in a gm crate motor ls1 or ls6? If it doesnt come with an oil pan i was wondering if the oil pickup tube is supplied and already installed. the reason i ask is i have a customer who had a crate motor installed and after 500 miles it failed due to the oring on the oil tube being improperly installed/ pinched.
that I know of they come oil pan to intake manifold
here is a website that says that also but at the same time says this exact part number is discontinued
http://gmhorsepower.com/LS1-Fuel-Injected.php
but I found that pretty quickly by doing a google search
here's another that comes minus the intake
http://www.crateenginedepot.com/stor...-P1625C63.aspx
ok forget those above both of these come oil pan to intake, even includes exh manifolds
http://www.gmperformanceparts.com/En...1268&engCat=ls
"GM Performance Parts delivers the LS6 as an all-inclusive assembly, complete with CTS-V oil pan, large-volume composite intake manifold with single-bore throttle body, and high-performance long-style exhaust manifolds."
http://www.gmperformanceparts.com/En...4322&engCat=ls
The engine is rated at 350 horsepower and 365 lb.-ft. of torque. The engine includes a GTO-style oil pan, electronic drive-bywire throttle body, intake manifold, exhaust manifolds, fuel rail with injectors, balancer, and 14" automatic transmission flexplate. It makes a great performance engine for your performance vehicle project – just add your wiring and electronics.
