what gaskets do i need for cam swap?
Ok im about to order a cam package from thunder and i was wondering what gaskets do i need. i have a 01 SS and i heard you dont need any gaskets just a longer crank pulley bolt??? Does the asp pulley come with the longer bolt i need? thanks alot
chet
chet
Re: what gaskets do i need for cam swap?
The pulley does not come with a balancer bolt...you'll need one. I suppose theoretically you don't need new gaskets but I'd buy them anyway. If your luck's like mine, you'll screw one up taking it off and you wont have replacements. Cheap insurance to replace them or have them handy. I'd buy the cam install kit from Thunder, too. It's pretty cheap as it goes. Don't they include it in the cam package you bought? You can reuse the valve cover gaskets but I'd get:
Water pump X 2
Front cover gasket and front crank seal
Water pump X 2
