What tools used to tap out head bolt threads??
Old 07-09-2008, 08:27 PM
nova2427's Avatar
Default What tools used to tap out head bolt threads??
I just removed a stud and I'm having a difficult time placing it back in and I wanted to know if anyone made a long tap or a tap extension to clear the threads out?
Old 07-09-2008, 09:14 PM
HavATampa's Avatar
Search is your friend.
https://ls1tech.com/forums/generation-iii-internal-engine/949297-cleaning-head-bolt-holes.html
Old 07-09-2008, 11:01 PM
Grimes's Avatar
you can grind down the side of an old head bolt, and run that through first to clean things out. Works well. Make sure there is no coolant in the holes btw, or you risk cracking the block
Old 07-09-2008, 11:22 PM
DanWS6's Avatar
That's what I did. I had bought a tap but after reading a few posts it appears that is not the way to do it.
Old 07-10-2008, 04:36 AM
vettenuts's Avatar
ARP males a thread chaser that doesn't remove metal, part # is home. That is what you need. Don't use a tap.
Old 07-10-2008, 09:41 AM
HavATampa's Avatar
Part number for the ARP thread chaser is in the link I added in the 2nd post.
912-0011
Old 07-10-2008, 09:42 AM
nova2427's Avatar
What do you mean grind down the side of a old head bolt? I'm just a little confused on what side?
Old 07-10-2008, 10:08 AM
HavATampa's Avatar
A lot of guys have done it this way, but I never have. Go to http://www.ls1howto.com/index.php?article=2 and scroll 1/2 way down, they talk about using the grinded down head bolt method.
Old 07-10-2008, 11:13 AM
vettenuts's Avatar
If he has any threads that may be partially damaged, I would not use this method, rather the ARP thread chased in post #2. This method could make things worse depending on the existing thread condition.
Old 07-10-2008, 11:52 AM
LS1C5Vette's Avatar
I used the stock head bolt grinded down on 2 head swaps now with no problems
Old 07-10-2008, 03:44 PM
nova2427's Avatar
Ok...that seems easy enough. I just couldn't get the stud to seat as far down in the block as It needed to be. hopefully this method will help, unless some of the threads are damaged, then I might need a tap. If so, does anyone know where to find a tap that long?
Old 07-11-2008, 05:11 AM
vettenuts's Avatar
The thread chaser in the above post is sold by SDPC and is long enough, it is made for this situation.
Old 07-12-2008, 12:40 AM
nova2427's Avatar
the original head bolt worked great...Thanks for the tip!
Quick Reply: What tools used to tap out head bolt threads??
