CNC Help!
CNC Help!
Hey everyone,
I need some help! I've got some old heads off of a 1999 TA with a casting number of 853. I want to clean up the ports and try to increase the flow. I don't have a probe or anything like that to check the surface of the ports. I would like to have a Mastercam or Solidworks file for the intake and exhaust port in there stock shape. Or is anyone in the Jacksonville,FL area has a Renishaw probe I can borrow, I would kindly appreciate that also.
Thanks,
Chris
Thanks,
Chris
I know there just about a stupid stock as you can get. It's just for fun, just to see if I can do it. I hope to improve them, as far as the flow goes. If I can machine these things just right, I'll put new valves and stuff in them and give them a test run. And if everything goes really well, I'll get some new castings and machine a fresh set!
