install snags
Old 08-27-2003, 05:47 PM
pdd
pdd's Avatar
Default install snags
on my c5 im installing a new cam. got the starter, water pump,radiator all out and half the power steering pump. i cant for the life of me get the 2 nuts out on the metal lines that go to the gear box on the stearrin rack. i tried the stupid 18mm flair nut wrench(bought it today just for that and napa bent me over 10bucks for one!!!)tried a regular 18mm wrench. i cant budge umm. any suggestions. i hate this 1/2 the car apart and im stuck
Old 08-28-2003, 12:37 AM
kp
kp's Avatar
Default Re: install snags
Once you take the PS pump bracket off the head/block (you can get at all the bolts with an open end wrench when you get the water pump off) and the ABS/AH module unbolted (take the three nuts off and lift it out of the bracket a little) if your car has active handling.
Once all of that is out of the way you can swing the p/s pump and bracket up and get at the lines from the top. If you already to that point, yes those lines are tight but they will crack loose with enough muscle. If there is room slip another box wrench over the flare wrench to make it longer - there isnt a lot of room there though. Get a 18mm crowfoot and a long handled 3/8 ratchet if all else fails.
Old 08-28-2003, 04:43 PM
JeffJeff's Avatar
Soak them with some WD-40 for about 5 minutes and use a hammer on the wrench (carefully) to get the nuts to break loose.
