Need Torque specs for oil pan install
Old 08-10-2008, 10:06 PM
AustinYukon's Avatar
Default Need Torque specs for oil pan install
I can't find it anywhere. I just installed my LH8 Oil pan on my engine before it goes in the project car. What am I supposed to torque these to?
Pick up tube (O-ring side)
Pick up tube (deflector side)
Deflector
Oil pan bolts
I might have tightened them a little too much.
Thanks!
Old 08-10-2008, 10:11 PM
STF Veteran
EvilStang's Avatar
http://www.ls1howto.com/index.php?category=1
remember every 12 inches = 1ft lbs tq
Old 08-10-2008, 10:36 PM
Thanks! I never knew that site existed. I also never knew the inches to pounds conversion. That doesn't seem right though. 106 in pounds is only 8 ft pounds on the baffle bolts.
I also don't see the pick up tube torque
Old 08-11-2008, 10:41 AM
STF Veteran
EvilStang's Avatar
here is the link to ft lbs to inches or vise vercia.http://www.convertunits.com/from/foo...s+pounds+force
Im not sure the exact TQ for the pick up tube. I Just tightened mine down until i felt that it was moderate tight and never had a problem with it.
