slp pulley removal
I pulled one once. I think I made a puller. It was a 3/16 plate that I drilled 3 holes in to bolt to the balancer. then a long bolt & nut welded in the center.
Maybe you could use a harmonic balancer puller if you can get the holes to line up. You can borrow them at checkers.
I have a puller that worked great. Just a standard puller from an auto parts store Kind of flat plate that's kind of shaped like a Y. There are no clamps but 3 bolts on the outside screw into the pulley and one large bolt in the middle pushes the pulley out.
