Need advise on H/C & piston slap
I have a TR224, AS stage 2's, pulley, lifters,Katech pump and chain Ect. to put in my car. But it has pretty bad piston slap. It has the paint can rattle @ 1500 rpm and also the loud tick. Both sounds continue after the car is hot. The rattle dose quite down some when hot but the tick gets worse.
Anyways, I was going to just pull the motor and put in forged pistons myself, but that is just to much $$$. Then i decided to just ignore it. Now I'am second thinking that again. It seems like these are my options.
1) Just install the cam and other stuff. And hope that the new pump O'ring & lifters fix the ticking noise. Then live with the rattle sound for a few years and get a stoker short block.
2) Have the dealer install new rings and or pistons (I have heard of them doing either) And hope this fixes it. Then install my parts. Also hope it stays together at the track after they mess with it. But then if it dose lets go I will be screwed because I will have voided my waranty with my cam install.
Atleast right now I am fiarly sure its not going to come apart on me. It's just embarasing at times
What do you guys think?????
Re: Need advise on H/C & piston slap
I got the same problem.(got a blower to put on)
My 2000 SS did it, my 2001 TA does it and my buddies 2002 Z28 does it! And a about a dozen others I drove did it
The same way you described!
Maybe its harmless and they all do it, let me know what you come up with.
I have knocking from pistons cold, it goes almost away hot. I have valvetrain noise but its consistant and pretty normal for my reduced preload setup and aggressive ramp rates on my cam. Piston noise is similar to race style forged pistons, that is why i am somewhat ok with it.Design and pin placement seems to be the reason for the racket, the way i see it, its better to be loud and fast than quiet and slow! LOL
If you want to have GM do it, you might take a look at this:
http://www.pistonslap.com
While there are obviously some pretty pissed people out there, that site does have some very good info as to the cause and possible effects of what that slapping does. Sounds like you've got a pretty good case of it.
If you're dealer will still do it, you might want to see if they actually have a fix, or if they're just going to stick the same size pistons in.
my 2.2 sonoma was stone silent....
Just drive it. I have ran the **** out of my car with H/C all summer 12K miles and havent noticed much of a change in my piston slap. Mines pretty bad, real loud when cold and you can still hear it after it warms up. Just turn the radio up and get a louder exhaust and forget about it. If it blows up in a 1-2 years build a stroker engine or build a forged 347 and spary the **** out of it thats my plan.
